Controller not populating in Online Controllers
I am having issues getting a controller to show in the Online Controllers section.
                * Using PLCNext Engineer version 2024.0.3 and a AXC F 2152 firmware 2024.0.0 LTS
                * PLC is able to be pinged from laptop, can connect to WBM, can connect to device from Engineer and write program to PLC.
                * Profinet MSG_ONL0185 error, no device MSG_ONL0166 error.
                * Tried various versions of npcap (1.6, 1.71, 1.78, 1.79), have .NET 7 framework installed.
                * When rebuilding program, no error occur - builds successfully.
I have a desktop computer that works just fine connecting to same controller with same program.
Any help would be appreciated. Thanks!
I have the same problem. I installed the latest .NET 7 framework, installed npcap 1.79 manually and re-installed PLCnext Engineer. Now sometimes the scan works but most of the time it does not. When I use Netnames+, all devices are found immediately. I hope there will soon be a solution.
I have the same problem. I installed the latest .NET 7 framework, installed npcap 1.79 manually and re-installed PLCnext Engineer. Now sometimes the scan works but most of the time it does not. When I use Netnames+, all devices are found immediately. I hope there will soon be a solution.</p>
I also have this problem. Is there any information about it?
