Convert INT64 to desimal so it can be shown on a webpage
I’ve got an issue with converting data from a modbus TCP. This is for transfer the total energy from a powermeter to a webpage. I got this information from the modbus adress list:
Address: 0x7D5F–0x7D62
Register: 32096–32099
RW: R
Unit: Wh
Type: INT64
Range: -
A/E: E
A/E/P/H: E/P/H
X: X
Description: Total active energy
Energy is stored in big-endian format: The most significant register is transmitted first.
Im using a 1152 CPU
Can someone help me making a LD or NOLD diagram how to convert it to desimal so I can show it on the webpage.
You should be able to use something like the following:
- Delcare an LWORD variable to hold the 64 bit number.
- Use MOVE blocks to move the four 16 bit words into the LWORD using dot notation, for example:
MyLWORD.W3 := FirstRegisterValue;
MyLWORD.W2 := SecondRegisterValue;
MyLWORD.W1 := ThirdRegisterValue;
MyLWORD.W0 := FourthRegisterValue;
- If necessary, use a TO_LINT block to convert the LWORD value to an LINT value, which you can display on the HMI.
Thanks, that help.
