Is it possible to save custom made function blocks and self written programs in PLCnext engineer? I’ve already seen the library map, but I can only add premade files to it. I would like to have my several programs and function blocks available when I program a machine instead of opening a project and save the project as a new file.
Hello Vince,
I hope I understood your question correctly.
to re-use your functionblocks you have multiple options.1. Create a Library that you can then import in every future project.(file → export → as IEC Library ; Libraries → User Library → yourLib.pcwlx)
→ Can not be modified and content of FBs can be hidden2. Import the Functionblocks directly from the project. (file → import → from another Project → select FBs you need and press Import)
→ FBs can be modified.kind regards,
Olver
