Hello, I’m testing out a bit with the data analytics on the proficloud. Where is the data saved? How much data can be stored? Is it also possible to do a action if a a variable gets some value? Not sure how I am able to perform this, and if it’s possible. Arne
Hi, the data is stored in the Proficloud, which is operated on AWS server in Germany. therefore, there is no limit of the ammount of stored data. In some weeks there will be a TSD Alarming solution in Proficloud, which will offer to create alarms based on the metrics in TSD Analytics. Arno
