Hi, I tried to wrote a very simple first example with C# and VS 2017. I could run the prog in PLCnext. Thats fine. It is running and I can add two values a = b+c. But if I try to enable the debug mode in VS, then this message box appears. It seems that the debug mode is running (I adjust also the settings files on the PLCnext controller → gateway, port, etc.) What could be the reason for that message box? PLCnext Firmwar 2020.6.1 PLCnext Eng. 2020.6.2 By the way. It seems that you need per Inputport variable a separate property definition. Can’t see the InputPort “c” in PLCnext Eng.
[Global, OutputPort] public int a = 1; [Global, InputPort] public int b = 2; `` public int c = 3; With this syntax I can see the InputPort “c” in PLCnext Eng. [Global, OutputPort] public int a = 1; [Global, InputPort] public int b = 2; [Global, InputPort] public int c = 3;
`` Thanks. Alex
