Demo license
I’m having troubles with demo licenses. I’m in the middle of a customers’ technical workshop and had requested to them to download and install PCWorx Engineer on their machines. After some hours working, PCWorx cannot be accessed anymore for one of them and below is the event log got from Code Meter license service for analysis. What can be done to solve this issue in order to keep alive this customer in this event and get back his demo license? Moreover, what happened with his license? PS.: The software was installed less than 5 days ago and its license cannot be expired 2018-02-28 17:12:05: CodeMeter for Windows (B6.50.2640.503.32.180)
2018-02-28 17:12:05: Running on Microsoft Windows 7 Professional Service Pack 1, 32-Bit
2018-02-28 17:12:05: Execution path: C:\\Program Files\\CodeMeter\\Runtime\\bin
2018-02-28 17:12:05: Found IPv4 address: 127.0.0.1 | 192.168.1.56
2018-02-28 17:12:05: Found IPv6 address: ::1 | fe80::b10c:9d39:ff35:2eac%15 | fe80::d817:b47a:9d5:c752%14
2018-02-28 17:12:05: Used Communication Mode (Client): IPv6 IPv4 SharedMemory
2018-02-28 17:12:05: Used Communication Mode (Server): IPv6 IPv4 SharedMemory
2018-02-28 17:12:05: Used IP address: default address
2018-02-28 17:12:05: Used IP port: 22350
2018-02-28 17:12:05: Used CmWAN port: 22351
2018-02-28 17:12:05: Multicast server search: not available
2018-02-28 17:12:05: Run as network server: no
2018-02-28 17:12:05: Run as CmWAN server: no
2018-02-28 17:12:05: Run as system service: yes
2018-02-28 17:12:05: Box Access: use direct access mode
2018-02-28 17:12:06: The list of available CmContainers has been updated!
2018-02-28 17:12:06: License file “6000217_8200a94f282b217cb28102fd6a8304af45608f34.WibuCmActLic” loaded successfully
2018-02-28 17:12:06: Detecting CmContainer with Serial Number 130-1545563101
2018-02-28 17:12:06: A new CmContainer is available (currently found 1)!
2018-02-28 17:12:06: Found new entries: 1
2018-02-28 17:12:06: Access from local(IPV6) to SubSystem (Handle 16)
2018-02-28 17:12:06: Handle 16 released
2018-02-28 17:12:07: Access from local(IPV6) to SubSystem (Handle 21)
2018-02-28 17:12:07: Handle 21 released
2018-02-28 17:12:30: Executing Broadcast for CodeMeter License Servers
2018-02-28 17:12:31: Access from local(IPV4)(NICARAGUA\\agpr5’) to SubSystem (Handle 29)
2018-02-28 17:12:31: Handle 29 released
2018-02-28 17:12:31: Executing Broadcast for CodeMeter License Servers
2018-02-28 17:12:32: FC:PC=6000217:1001000 : Usage Period is expired.
2018-02-28 17:12:32: Entry (6000217:1001000) not found - Event WB0071 (BOX ERROR), Request IP-Address local(IPV4)(NICARAGUA\\agpr5’,Ade.Shell) with StationShare Mode
2018-02-28 17:12:32: API Error 71 (BOX ERROR) occurred!
2018-02-28 17:12:35: Executing Broadcast for CodeMeter License Servers
2018-02-28 17:12:36: Access from local(IPV4)(NICARAGUA\\agpr5’,Ade.Shell) to FC:PC=6000217:1001000 with StationShare Mode (Handle 31)
2018-02-28 17:12:36: API Event WB71 (BOX ERROR) occurred (returned to caller)
2018-02-28 17:12:36: Handle 31 released
AXC_F_2152_LED_Diagnostics.pdf
Is there a full log you can provide, including the installation/setup from codemeter, 5 days ago (to check the timestamps). Perhaps the system-time of the vm-image (5 days ago), wasn’t synced to an NTP server, or due hibernation issues, and has catched-up in the meantime. Normally the license is working for 30days before shutting down. Personally I haven’t seen any issues with reduced usage-window. another thing you could try is to activate the emergency licence in such an event, but keep in mind this can only be done a single-time., and buys you a limited additional usage.
Hi Eduardo, it seems for me that you’re using a virtual machine, in that case please keep in mind that the licence is HWbound. Means any (major) changes on the HW settings (RAM, CPU…) can “break” the licence. Please follow the recommendations in the FAQ to have also good results by using VM Wares. For the licence you’ve please you can send to me the licence container to reactivate it. cu Frank
