Using a AXCF3152 (2022.0) and inspecting the logs at /opt/plcnext/logs/Output.log there is the following being constantly logged:
30.09.22 17:14:56.095 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident “Status.Interfaces.Ethernet.4.1.Duplex” not found 30.09.22 17:14:56.096 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident “Status.Interfaces.Ethernet.4.1.Baudrate” not found
Any reason why this is occurring? It makes viewing the logs very annoying (I can use grep to remove this, but I’d rather understand the root cause of this).
Kind Regards,
Joshua
The same question was asked and answered here:
Forum - PLCnext Community PLCnext Technology from Phoenix Contact is a unique, open ecosystem for modern automation that is capable of meeting all the challenges of the IoT world. The problem should be not so bad when using firmware version 2023.0 LTS, but eventually the problem will need to be solved in PLCnext Engineer.
