I’m setting up a new AXC F 3152. I used the Online Parameters to set the desired IP addresses and that all worked very nicely. However, the DNS hostname did not change like I had hoped it would. On interface 1 I am using DHCP with our intranet DNS servers. It registered the default hostname of axf3152 rather than the hostname entered in the online parameters. If I set the desired hostname to /etc/hostname it works as intended. Should the online parameters be setting this, or is the DNS hostname in Online Parameters used in a different way? Thanks, Rob H
Hi Rob, the form in PLCnext Engineer does already include the field, but unfortunately does it not call the service behind. But you can use the PLCnext Base library to read the given (from DHCP) and to write the DNS name of the device. Hop that helps, Frank
Hi Rob, I’m sorry, obviously I’ve made a mistake. The FB PBCL_SysNetwork_1 can set the DNS Server as part of the general network configuration, but can not set the device hostname. For now this can only be done by modifying (as root) the file /etc/hostnam. We’ve add this feature as a requirement and are currently evaluating when this can be done. Sorry once again, Frank
