Hello, We have some questions when using the set time function block “SetClock” in the plcnextbase library. Time can be written to PLC system normally, but it will become the original time if power is off and restart. I have tested many times and found that if I use reboot command through putty, it is OK, but the direct power-off restart time cannot be maintained I think it may be necessary to write and save after the setting is successful. Can you help solve this problem? Because it’s a normal situation to power off and restart directly. ps.PLCnextBase_1_1_0
Hello, this is a known issue and will be fixed in the next version. Kind regards
Hello Sir, When will it be released? Is there a schedule? Thanks a lot!
Hello, the next release is scheduled for the first half of 2020. Kind regards.
