When placing my original c++ program into the eclipse ide is this the correct way to implement the program or should I move „#include …“ with the others at the top? Edit: Also when implementing my program should I delete my void main function or leave it?
Hello nazirlouis38 ; #include is a pre-processor directive in ‚C/C++‘, please don’t include it into method! The „Execute“ method will be called as „program“ in a cyclic or event Task (see task configuration in PLCnext Engineer). The „main“ program will be don’t needed, please remove it! Please see the following description, E-Learning and Videos, I think it will help you: 1. PLCnextInfoCenter 2. Tutorial Videos 3. E-Learning 4. C++ Examples 5. C Programming tutorial Best Regards Eduard
