Hi, I am facing problem while opening a new project in eclipse on Linux. Attached the screenshots. I had earlier installed eclipse and had built projects. However, with some ubuntu issues , I had to re-install Ubuntu, and hence re-install eclipse and set up the whole build environment. I have installed the eclipse Add-in for PLCnext technology. Regards, Umesh
I had the same problem and i solve it by using an older Version of eclipse
Yes, Hermann’s solution is the correct one - according to the PLCnext Info Center, the recommended Eclipse version is Photon (9.5.2). Martin.
Hi, I am not able to find the Eclipse Photon (9.5.2) for Linux. If anybody has the link to the downloads kindly share. Regards, Umesh
Hi Umesh, Here is the link. https://www.eclipse.org/downloads/packages/release/photon/r/eclipse-ide-cc-developers Martin.
Thanks Martin.
