Hi All I’ve embedded the eHMI’s of several PLCnext Controllers inside I-frame’s in a SCADA project.
This was handy as we had already built the pages but we wanted to have some portal to have it all connected to each other. You can use a normal i-frame if your SCADA program supports it, but you’ve to remove the X - frame headers inside the /etc/nginx/nginx.conf file. Reboot the controller and you should be good to go! Kind regards! Dries
