Enable and disable Profinet header
I would like to enable or disable different profinet headersf for program using the AXC F 3150 plc
Hello Ventura,
I hope I understand your request correctly, if you don’t need the PN-functionality you can deactivate it in WBM. By program implementation you don’t need the Profinet headers.
BR Eduard
Hello Ventura,</p>I hope I understand your request correctly, if you don’t need the PN-functionality you can deactivate it in WBM. By program implementation you don’t need the Profinet headers. </p>BR Eduard</p>
Hello,</p>I would like to enable or disable different profinet headersf for program using the AXC F 3150 plc</p>
Thanks Eduard,
I want to spend PN-functionality but I can’t find it. For the RFC470s and earlier models I use AR_MGT but for PLcnext it is new to me.
BR Ventura
Hello Ventura,
the PN-Controller and PN-Device functionality are activated on PLCnext Controllers by default. You can configure/use it in PLCnextEngineer see: Forum - PLCnext Community (plcnext-community.net)If you would like to deactivate this services you can do that in WBM under System Services: Configuration - System Services (plcnext.help)
BR Eduard
