Entire project backup
Is there any method to backup entire project that runs on AXC F 2152 (including iec61131 programs, linux’s app, configuration etc.)?
Hello Konrad, One way to do this is to copy the entire contents of the directory /media/rfs/rw/upperdir to your backup location. This directory contains the overlay file system that is used to store every file that is changed on the PLC. - Martin.
Hi Martin, The new AXC F 2152 has an internal memory and an SD card. But, os is in internal memory and only use an SD card for ordering data,…etc. My question is: How i can copy the entire contents of the directory /media/rfs/rw/upperdir to my backup location, from internal memory? I look forward to receiving your response! Thanks!
Use WinSCP and just drag and drop it to your host
{jcomments on} Hi Martin, The new AXC F 2152 has an internal memory and an SD card. But, os is in internal memory and only use an SD card for ordering data,…etc. My question is: How i can copy the entire contents of the directory /media/rfs/rw/upperdir to my backup location, from internal memory? I look forward to receiving your response! Thanks! {jcomments off} Hey thanhlx1911,
the “/media/rfs/rw/upperdir” martin mentioned will always be the location where your project is stored.
It just gets mounted to the different SDs / Partitions. So the solution Arne Smets provided is correct.
You can connect to the PLC via SCP and copy the files. kind regards,
