Error when creating C++ project in Eclipse
Dear people, If I create a C ++ project in Eclipse this error will occur. Does anyone know how to solve this? Kind regards, Bart MintenError
Hello bart_minten, could you give me information about the version of used plcncli, please? CMD command:
C:\\Users\\pyme04>plcncli --version
plcncli 20.6.0.355 (20.6.0.355)
Thanks! ~Eduard
Hello Eduard, First of all, thank you for your quick response. When I put the command in CMD you said above here, the result is (see image). I didn’t get the the version of the PLCnCLI. Error1 Kind regards, Bart Minten
Hello Bart, this could be a issue with .NET 3.0. Please try to delete the folder “plcncli” in %Temp%\\.net\\ and restrart the system/plcncli tool.`` If the failure persists, could you deinstall the plcncli tool and install the current version (plcncli 20.6.0.355 (20.6.0.355))?
~Eduard
Hello Eduard, I did all the things you recommended to do to solve the problem. Unfortunately, it hasn’t helped me further. I have the same error as at the beginning which I mentioned above. Kind regards, Bart Minten
Hello Bart, is it possible to start a FastViewer Session today at 14:00 o’clock? If it’s possible, please download and run the FastViewer application (I’ll provide you the Session number): http://fv.phoenixcontact.com/client/fastclient.exe ~Eduard
Hello Eduard, Thank you for your commitment to help me resolve my issue. I appreciate your offer for helping me out with the PLCnCLI. But yesterday I already contacted a colleague of yours from the Netherlands. I haven’t got any response yet, but he has helped me a few times ago. So I trust he will help me when he sees my email. Kinds regard, Bart Minten
Hello Bart, no problem, if this issue can’t be resolved, please let me know or my colleague from the Netherlands can contact me via our ticket system. Then we can analyze this issue in detail. ~Eduard
Hello Eduard, If it is still possible yet, I would like to have a fastviewer session with you about my problem. I spoke with your colleague from the Netherlands and he said that you are the most likely person who knows how to solve this problem. What time works best for you? Kind regards, Bart Minten
Hello Bart,
yes, we can start the fastviewer Session at monday (02.11) in the time window of 09:00 - 15:00 o’clock ?
Please send me the time, when it best suits you. Thanks! ~Eduard
Hello Eduard, Monday (02.11) 11:00 0’clock suits me the best. I only have to install fastviewer for this meeting, haven’t I? Or do I need something more. Kind regards, Bart Minten
Hello Bart,
OK, I will provide you the FastClient Session ID today at 11:00 0’clock. For remote support please download and run the FastViewer application: http://fv.phoenixcontact.com/client/fastclient.exe
~Eduard
