Error when trying to install Eclipse Add-in for PLCnext Technology on Linux (VM)
Hey,
Right now I am working on a project which includes PLCnext and machine vision using OpenCV. I followed this Tutorial here using a VM with Ubuntu 16.04.1 LTS 64-bit
During the install process of Eclipse (following this video) the following error occurred when I tried to install the Eclipse Add-in for PLCnext Technology : Cannot complete the install because one or more required items could not be found.
Software being installed: PLCnext Technology C++ 19.0.0.747 (com.phoenixcontact.plcnext.cplusplus.feature.feature.group 19.0.0.747)
Missing requirement: PLCnext Technology C++ 19.0.0.747 (com.phoenixcontact.plcnext.cplusplus.feature.feature.group 19.0.0.747) requires ‘org.eclipse.ui 3.109.100’ but it could not be found Thanks a lot in advance,
Kind regrds,
Kilian
Hey Kilian, it might be that you are running a to old eclipse version. You will need at least photon for the latest Eclipse plugin. kind regards,
Hey Oliver,
Thanks a lot for the fast reply. This was indeed the problem. kind regards,
Kilian
