Good Morning, I am receiving an error through packet reading, saying that the ReductionRatio Parameter is incorrect. However, I am unable to find the option under profinet to adjust this ratio, as PC Worx has. Does this mean my GSDML is wrong, or does PLCNext Engineer simply not have the ability to select ReductionRatios? Thank you. EDIT: Updated PLCNext to 2019.6, which enabled me to adjust the timing as I needed.
