External SD Card on AXC F 3152
Dear All,
I hope everyone is have an amazing day, I have an AXC F 3152 PLC and the storage on it is not enough for the files i want to download, so I bought a 64 GB SD card from Sandisk and I intalled it on the PLC then I turned it on.
When it is booting all the lights on the PLC flash red, I am aware that the PLC attempts to boot from the SD card but how can I use the SD card as storage for my PLC, I want to download a couple of programs I need and I need some more storage.
Any ideas on how I can fix this?
Thank you so much for your help!
Hello retrospective,
please note only the SD-Cards from Phoenix Contact can be used.
Please see the Info under following link: SD cards (plcnext.help)
BR Eduard
Dear Eduard,
Is there no other way to use an external(Non Phoenix Contact) SD card? even if it is unsupported just point me to it.
Thank you
the use of third -party memory cards is not supported by Phoenix Contact.
Please find the following information uder following link: SD cards (plcnext.help)"These SD cards come with an underlying file system, which is necessary for proper operation in PLCnext Technology. Do not use other SD cards available on the market, nor reformat a Phoenix Contact SD card you want to use with your PLCnext Control further on. "
