FC3 -Modbus RTU 11 -Addresses Scan
Hello everyone,
I need some advice on how to pass the addresses contained in an Array, defined as List_Address 0..16, to the FC3 block of the MOD RTU 11 library.
Addresses are inside the “List_Address” array. I created a for loop that scans the array from 0 to 16 and if the answer is positive it goes to the next address. But I need to stop the for loop, long enough for it to get the response from block FC3.
Thanks for your help .
Seems it is the same
Forum - PLCnext Community PLCnext Community
the FC 3 can be created several times with the corresponding slave address or it has to deactivate the FC after each response, reconfigure it and send it again.
kind regards,
Seems it is the same</p>[https://www.plcnext-community.net/forum/#/discussion/2816/addresses-scan-modbus-rtu-11</a></p>
i try this, i did something similar and it work. thanks man
