Feature Request: Simple Expressions Support in Function Block Worksheet
If there could be support for simple expression like this, the code worksheet will be more readable and clean. The blocks like OR, AND, GT takes a lot of space. And the younger generations are able to read expression like this.
Hi TeTi,
This implementation does not work in the FBD area in the IEC 61131 context.
This application could be implemented in ST, for example.
Hi TeTi,</p>
This implementation does not work in the FBD area in the IEC 61131 context.</p>
This application could be implemented in ST, for example.</p>
Hi Marvin,
Of course, Phoenix Contact wants to remain within the IEC 61131 standard. However, this could be a unique selling point for PLCnext Engineering in the marketing. That’s why I want to hear from other users to find out if they want something like this too.
We use a lot of mixed code in both ST and FBD because FBD gives us a better overview when debugging and making quick changes. So why not embrace the future?
Putting ST in FBD could turn very messy - and the overview you cherish would be lost.
If you like textual expressions, use ST.
