Hello. I have a question regarding the new firmware 2019.0 LTS. This firmware solves the Known Limitations of the former firmware 1.2.0 ? ------------------------- – Time-outs during the communication with PCP devices If more than eight PCP devices are connected at the same time, time-outs can occur during the communication between the controller and the PCP devices. – Maximum permissible number of AxiolineF local bus devices Currently, a maximum of 30 AxiolineF local bus devices is supported. – Interrupting the PROFINET communication When transmitting files via SFTP to the controller, the PROFINET communication is interrupted. – Function of the reset button When the controller is reset to default setting type2, all LEDs light up after approx.30s. To actually restore the controller to default setting type2, you need to press and hold the reset button for another 2s after all LEDs have lit up. Thanks for your help. Best regards. Julian.
Hello Julian, the described “Known limitations and errors” are resolved. Please see the document “AXC F 2152 – CHANGE NOTES” in download center. https://select.phoenixcontact.com/phoenix/dwl/dwl13a.jsp?fct=dwl&asid;=4330692&name;=ah_de_axc_f_2152_change_notes_108427_en_06.pdf&prodid;=2404267⟨=de&hwv;=&debug;=0 Best Regards Eduard
