Is it possible to force the I/O of the AXC F 2152? I have tested this based on the help file and was unable to force an I/O point. The help file stated “NOTE: Depending on the controller type used, forcing may not be supported in the current version.” Does the AXC F 2152 support this functionality? If not, is it planned to support it in the future?
Hello Josh, yes it is planned to enable this feature also for the AXC F 2152.
It will be available in a future version.
Maybe even 2019.9 but I can not promise you that.
kind regards ,
