Freeradius balena container stops running
I was trying to run freeradius as balena-engine container. I followed: freeradius/freeradius-server - Docker Image, I was able to get the container to run, but it stopped after 3 sec. can you see what went wrong? I am using balena v1.0.0 and firmware 2021.6.0
The problem has been solved - the image being used was for x64, not ARM. (Ref: #216910)
