I am struggling to capture the current time in the local timezone. The controller is synced with a NTP server. I set the timezone to US Eastern and the $ date command returns the correct time in the correct timezone. I first tried using the PBCL_DateTimeGetString FB from the PLCnextBase library. It returns the correct UTC time. I tried creating a C# FB that used DateTime.UtcNow.ToLocalTime() but that still returned UTC time. It was suggested in this post to create C++ FB, but unfortunately I am unfamiliar with C++ development. Also, I have tested this on 2019.9 & 2020.0 with the same results. Any suggestions? Thanks, Rob
Hi Rob, I’m sure you’ve tried it, but out of interest, what does DateTime.Now() give you? ~ Martin.
DateTime.Now also returns UTC time.
Hi Rob, I have reproduced the problem you are seeing with the DateTime.Now function. This seems like a bug to me, but I will check this with the experts here. ~ Martin.
Hi Rob, A short update. It is possible to get the local time using the “RTC” system variable in PLCnext Engineer. This variable has been introduced in a recent version of PLCnext Engineer, and wasn’t available at the time of the earlier post you linked. I will find out the answer to the DateTime.Now question and post it here, in case you are interested, and for future reference. ~ Martin.
Martin, Go to know about the RTC clock. That will solve my immediate problem. I also contacted the PLCnextBase developers. They mentioned a new release with FB’s for UTC to Local Time and more. That will be ideal. Thanks for the quick repsonse, Rob
For others interested in this issue, it has now been confirmed that the problem with DateTime values described in this thread is a bug in the firmware (as at version 2020.3.1), and will be fixed in a future release. Sorry for the inconvenience. ~ Martin.
In the interests of closure: This issue has been fixed in FW 2020.6.1. From the change notes:
From this version on, the block “RTC_S” returns the local time, provided a time zone with root rights has been set before. In previous versions, the UTC time was always returned.
This solution is provided by a bug-fix that also fixes the
DateTime.Nowissue discussed in this thread. ~ Martin.
