Hello! I found a small detail in PLCNext Engineer that may not be very important, but I want to share it. When you create global variables in PLC area, and you want to use them in any program, they can be called without problems if the program is developed in FB. But if the global variables are called in Ladder, they have to be ‘created’ again as External, by lucky these are not duplicated, they simply have to be defined once more. If this is normal, maybe it can be corrected in the future Firmware…
Greetings.
