Help on IEC 104 Communication Function Block
Hi, I am dealing with ILC 151 GSM/GPRS PLC. I need to send PLC digital IO and Analogue IO to one SCADA through IEC 104 protocol along with Modbus TCP to other SCADA. I got Resy 104 and Resy Basic Libraries. But when I tried to get Help on FB, nothing is showing. Is there any way to get Help on FB for Resy 104 and Resy Basics library blocks in English Language?
Hello shahzadvs, please note that this Forum is for PLCnext Technology and PLCnext Engineer and not directly for classic PLC’s and PCWorx 6. I’ve created a support ticket and my colleges from the support team for Classic PLC’s and PCWorx 6 will answer your question. For future questions about Classic controllers or PCWorx6, please contact the AUTOMATIONWORX HOTLINE at: +49 5281 9462888 or by e-mail: automation-service@phoenixcontact.com Take care Eduard
Hello shahzadvs, I get the following reply from support team for PCWorx 6: “Generally, the help for the FB should be available as a PDF with the downloaded PCWorx libraries. If you need additionally support for Resy Librarys, please contact the PxC-Support team in your country”. Please find under following Link the help file for the Resy104. There is no help file for the ResyBasic, because this is a libraty that we only use internaly to have standard funtionalities in a separate library for all the other libraries like the ReSy104. https://phoenixcontact.sharefile.eu/d-s590d860e1ff406d9 Best Regards Eduard
Hi experts.
I’m using ResyBasic and Resy104 library with ILC 171. ILC works as IEC 60870-5-104 slave device.
Can ILC connect concurrently to 2 or more IEC 60870-5-104 Remote control System?
Thanks
