HMI - Button - Open URL
Hi, I would like to use a button in the Web page to download a Datalogger file form PLCnext. I have tested the action On Click > Execute command > Open URL. It work well. But my files have dynamics names (name is composed by the data/time) and in the Command URL Field is possible only to insert a fix url. Is there any way to use a variable or tag in the Command URL Field of the action Execute command > Open URL ? Thank you, Sidnei Marcondes
Hi Sidnei, I’ve received the following feedback from the development:
Hello
On Click > Execute command > Open URL do not currently support variable/tag string as input to the dynamic property. The new release of PLC Next Engineer eHMI (2021.0), a new feature will be added to where the dynamic can except a string variable. This will allow you to have the functionally you are looking for.
Hope that helps, Take care, Frank
