HMI "Symbol List", missing feature / bug
Hi folks,
It’s me again.
I am exploring the possibilities of the HMI and wanted to use the built-in “Symbol List” which is supposed to take an array variable and spread information across several instances of a premade symbol.
My first snag was that the two input fields for the property of the Symbol List is missing in PLCnext Engineer 2023.6 compared to the help file:
Namely the Start- and End index fields which let me determine to use parts of the array and not all of it.
My second snag is that if the symbol I use in the Symbol List has a “Page”-parameter, it is not possible to use the Symbol List.
The reason is that it is not possible to select an HMI page.
The “Source type” should be Page, not “field”.
Below is the dropdown menu I expect when trying to select a page (this is from the Symbol I am attempting to use in a symbol list, but when used individually)
image.pngMaybe or can check this?
I have passed this message to the HMI Support team, and also to the technical experts in your local Phoenix Contact office.
