How to configure the ComSiemens library with a Siemens Controller and a PLC AXC F 2152?
Hello, I have installed the ComSiemens library from your PLCnext Store. With this library I want connect my Siemens S7-1500 to the Staterkit Controller (1188165). In my PLC AXC F 2152 (2404267) I want to read one simple input and output from my Siemens Controller. The datatype from the variables are Bool. The two PLC controllers are currently connected with the profinet cable.
                                             1. Must there are any settings done in the TIA Portal or in the controllers?
                                             2. How can I find the Siemens Controller in the PLCnext Engineer Software?
                                             3. Is there any example project where I can see how to match the variables from the two controllers into the function block?
thanks in advance Best regards
You need to activated PUT/GET in the controller.
