How to switch of Profinet
Hello, What about the current solution how to switch off Profinet (AXC F 2152)? Thanks.
Hi Dzmitry, The current method is shown in the Sample Runtime series of articles, here: https://github.com/PLCnext/SampleRuntime/blob/master/getting-started/Part-09/README.md Note that this method of disabling Profinet is currently only recommended for applications that do not use PLCnext Engineer. Otherwise, errors will occur during startup that are not simple to work around. We hope that this will be fixed in future firmware versions. Martin.
Hi Martin, Our application uses PLCnext Engineer, so looking forward future firmware version. Thanks a lot.
