Hi. The information of IPSec was posted in the UM of AXCF2152, only three commands were listed. I opened the ipsec.conf, the selfcert.der, peercert.der, and mycert.pem were used. These certification file can not be found in the PLC. Can you give me some more guide on the use of IPSec? Thank you.
Hello, I forwarded your request to development and will provide you the needed information asap. Best Regards Eduard
Hello girch, I have good news, the MGuard app is planned to be published in the PLCnext Store in the week after next, on July 10, 2020 (see in https://www.plcnextstore.com/#/). This App will help you to configure the needed settings. As second way you can generate the cert-data: “selfcert.der”, “peercert.der” and “mycert.pem” in the mGuard secure cloud. The certificates and private keys referenced in /etc/ipsec.conf should be copied into the directory: “/etc/ipsec.d/” in the respective subfolders. For detailed information please see the following documentation: https://www.strongswan.org/documentation.html For example: File Destination at controller PRIVATE_CERTS.pem /etc/ipsec.d/certs/ VPN_CONNECTION.pem /etc/ipsec.d/certs/ PRIVATEKEY.pem /etc/ipsec.d/private/ Best Regards Eduard
Thank you for your guide.
