I want to install Node-Red but I am missing the IPKG install mananger
I would like to install Node Red but I am missing the IPKG install manager. I ssh’ed into the PLCNext, logged in as root and ran the following command: sudo ipkg install node And the PLC returned this: sudo: ipkg: command not found I have attached the relevent screen shots. Thanks for the help.
Hello, please have a look at this MakersBlog.
IPKG is not a Part of the PLCnext FW. You can also install node using the PLCnext Store. kind regards,
