report.txtDear support team,
I have a constant IDE crush when use column selection and manipulating (delete) code in ST.
Please find out generated report attached.
Best regards.
Dear Oleksandr,
thanks a lot for reporting the issue. I created an entry with your information in our internal defect database for investigation.
If I need further information or can give any feedback to you, I will write it inot this entry.
Kind regards
Carsten
And here is your feedback:
We found the issue and fixed it in PLCnext Engineer 2022.9 ![]()
