IEC60870-5-104 Server library
Dear Expert.
I’m testing AXC F 2152 PLC with IEC60870-5-104 Server library from PLCnextStore.
A problem relating to Double command signal please.
As Configuration of Library, Double command signal is Bool Signal ( See picture).
In fact, When IEC60870-5-104 master send double command with 2 values
* Value 2 refer to Close command. Double command signal in AXC F2152 will be true in some second and return to zero after then. It was OK.
* Value 1 refer to Open Command. Double command signal in AXC F2152 Don’t change any thing.
Please support me with Open Command problem.
Many Thank
Dear #all
Anyone can support please?
Thank
The developers of that app will be able to help with this question.
You can contact them by using the “Contact Developer” button on the app page in the PLCnext Store.
The developers of that app will be able to help with this question.</p>You can contact them by using the “Contact Developer” button on the app page in the PLCnext Store.</p>
Dear Sir
Thank for your feedback.
I also sent request on development button many days ago.
I understand that the developers of the app have now answered all outstanding questions that were submitted through the PLCnext Store. Please continue to use that channel to raise any new issues with the developers.
