Hello, I try to import times with Engineer’s PBCL_FileCsvRead_1 function from csv file, but it does not work. It seems that times are not supported as they result in t#0s entries in variables. Other data types work correctly. Where get I information about supported data types? Work around would be to use udint in milliseconds and change with to_time everywhere needed - is this the way to go? PBCL_FileCsvRead_11(uiOffset := UINT#1,
strFileName := STRING#‘IEC101_Connection_parameter1.csv’,
strDataTypes := STRING#‘STRING; (…) ;TIME;TIME;BOOL;TIME; (…) ,
strDelimiter := STRING#’;',
anyTable := arrParameterIEC101connect, following times were without strings before, none of it is working: tPollTime | tSendTestFrame | xControlE5Allowed | tTimeoutConnection—|—|—|—
100 | 10 | 1 | t#10s
0 | 0 | 0 | t#10s
0 | 0 | 0 | t#10s
