Hello I would like to use the google agenda and control it from node-red. so, I have followed this quickstart. Everything is clearly explained, and it works fine because I tested it on a Ubuntu PC. but on the AXC F 2152, it doesn’t work. after installing :
npm install [googleapis@39 --save > ](mailto:googleapis@39 --save)then, I created the index.js file, as explained in the quickstart. But, after the command
node ., I get this :admin@axcf2152:~$ node .
/opt/plcnext/index.js:8
is
^ReferenceError: is is not defined
at Object. (/opt/plcnext/index.js:8:1)
at Module._compile (internal/modules/cjs/loader.js:701:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
at Module.load (internal/modules/cjs/loader.js:600:32)
at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
at Function.Module._load (internal/modules/cjs/loader.js:531:3)
at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
at startup (internal/bootstrap/node.js:283:19)
at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)So, what can be the error? Can you help me? Please notice that I followed exactly the same behaviour on my Ubuntu PC, and it worked fine in 5 mn. !
