Hello, I began with the new software PLCnext Engineer, I consult them where I find the option to condition the blocks, example. > the coparations, mathematical operations, move, etc. I have attached a screenshot of where I found this on PCworx. this to better explain my query. Thanks ..
Hi Carlos, This feature is currently planned for PLCnext Engineer version 2021.0, due for release at the end of this year. Until then, it is possible to achieve a similar outcome using a SEL block after the block you would like to enable/disable. Something like this: ~ Martin.
