Installing arm-pxc-linux-gnueabi-gcc?
How can I install this package on PlcNext ? arm-pxc-linux-gnueabi-gcc Thank You
Hello diwa130, the compiler “arm-pxc-linux-gnueabi-gcc” is a part of PLCnext SDK, it is available for Linux 64 System (and Windows 32Bit/64Bit Systems). Is there a reason, why you need to install the “arm-pxc-linux-gnueabi-gcc” on PLCnext Controller ? You can also use the Windows or Linux OS for project build, it is faster and you will avoid a lot of PLC limitations. Best Regards, Eduard
To compile python packages for example :). You can use ipkg or dpkg packages for this, but they may lack the necessary dependencies. I haven’t dared to do this yet, it usually turns into a lot of work. What exactly do you want to do?
I need confluent-kafka and when I try to install , I get the following " unable to execute ‘arm-pxc-linux-gnueabi-gcc’: No such file or directory " Thank You
Hi, try this https://github.com/PLCnext/Docker_GettingStarted and https://docs.confluent.io/platform/current/quickstart/ce-docker-quickstart.html G Jan
