Installing Nodejs
I’m following the steps in this pdf to install Nodejs https://www.plcnext-community.net/index.php?option=com_easydiscuss&controller;=attachment&task;=download&tmpl;=component&id;=4&Itemid;=225⟨=en p.11 says : cd node cd bin ls -lsah This will show us two files: node and npm I don’t have a bin directory, so i’m not sure what i’m doing wrong.
Hi Arne, node is a symbolic link to the directory /home/root/node-v6.11.0-linux-armv7l, that you created in the previous step. Do you have the directory /home/root/node-v6.11.0-linux-armv7l (or similar, based on the version of node you installed) ? If so, do you see bin in that directory?
No I can’t see a bin in that folder. Because I am not able to acces home/root (I don’t no the password as it is not the same as I log in as SU), so I made the same directories underopt/plcnext/apps. I made the symlink and in there are different folders (tools, test, src, lib and more) and also a lot of files (makefile, license, configure, node-v—, vcbuild.bat and more). Arne
Hello Arne, try using this instead. https://www.plcnextstore.com/#/47 the tutorial you are using is quite old. (but still valid in most parts)
you first have to create a root user. “sudo passwd root”
I tried it that way, after some configurations I was able to download, but after about 30% it goes to “100% uninstalled”. after reboot I see nothing new in Winscp. EDIT This is in the outputlog: 30.09.19 14:58:11.858 Arp.Services.ProfiCloud.Internal.Processes.BaseProcess INFO - Installing app 60002172000109
30.09.19 14:58:11.858 Arp.Services.AppManager.AppManager INFO - Enabling installation Mode
30.09.19 14:58:11.859 Arp.Services.AppManager.AppManager INFO - Installation Mode enabled
30.09.19 14:58:11.859 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000109 install state to DOWNLOADING
30.09.19 15:01:25.242 Arp.Io.EthernetIP.EthernetIPComponent INFO - 2902328000 LogStatistics cycle=25/27, active=0/3, esdk=0/3, gds=0/1
30.09.19 15:15:29.212 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000109 install state to INSTALLING
30.09.19 15:15:29.213 Arp.Services.AppManager.AppManager INFO - Installing app from /tmp/60002172000109.app
30.09.19 15:15:29.544 Arp.Services.AppManager.Services.Internal.AppManagerServiceImpl ERROR - InstallApp failed with TargetIncompatible: Error while in plcnext app command: install /tmp/60002172000109.app 60002172000109
30.09.19 15:15:29.544 Arp.Services.ProfiCloud.Internal.Processes.BaseProcess ERROR - Error while installing app 60002172000109. TargetIncompatible - Error while in plcnext app command: install /tmp/60002172000109.app 60002172000109
30.09.19 15:15:29.544 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000109 install state to UNINSTALLED
30.09.19 15:15:29.544 Arp.Services.AppManager.AppManager INFO - Disabling installation Mode
30.09.19 15:15:29.544 Arp.Services.AppManager.AppManager INFO - Installation Mode disabled
Hello, I have the same problem: “Uninstalled 100%” when tryong to install NodeJS using PLCNext Store. I use Firmware version: 19.9.0 What can be the cause?
Additional Info: 02.10.19 07:58:39.656 Arp.Services.AppManager.AppManager INFO - Enabling installation Mode
02.10.19 07:58:39.656 Arp.Services.AppManager.AppManager INFO - Installation Mode enabled
02.10.19 07:58:39.656 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 install state to DOWNLOADING
02.10.19 08:08:51.989 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 install state to INSTALLING
02.10.19 08:08:51.990 Arp.Services.AppManager.AppManager INFO - Installing app from /tmp/60002172000051.app
02.10.19 08:08:52.179 Arp.Services.AppManager.Services.Internal.AppManagerServic eImpl ERROR - InstallApp failed with AppUpdateError: Failed to get app info from /tmp/60002172000051.app
02.10.19 08:08:52.179 Arp.Services.ProfiCloud.Internal.Processes.BaseProcess ERROR - Error while installing app 60002172000051. AppUpdateError - Failed to get app info from /tmp/60002172000051.app
02.10.19 08:08:52.179 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 install state to UNINSTALLED
02.10.19 08:08:52.179 Arp.Services.AppManager.AppManager INFO - Disabling installation Mode
02.10.19 08:08:52.179 Arp.Services.AppManager.AppManager INFO - Installation Mode disabled
additional info using Firmware 2019.6.3: 02.10.19 08:41:41.337 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - New app 60002172000051 install state is INSTALL_REQUESTED
02.10.19 08:41:43.151 Arp.Services.ProfiCloud.Internal.Processes.BaseProcess INFO - Installing app 60002172000051
02.10.19 08:41:43.152 Arp.Services.AppManager.AppManager INFO - Enabling installation Mode
02.10.19 08:41:43.152 Arp.Services.AppManager.AppManager INFO - Installation Mode enabled
02.10.19 08:41:43.152 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 install state to DOWNLOADING
02.10.19 08:42:11.610 Arp.Io.EthernetIP.EthernetIPComponent INFO - 2902328000 LogStatistics cycle=25/26, active=0/2, esdk=0/2, gds=0/2
02.10.19 08:43:46.011 Arp.Io.EthernetIP.EthernetIPComponent INFO - 2902328000 LogStatistics cycle=25/28, active=0/2, esdk=0/2, gds=0/2
02.10.19 08:55:06.879 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:55:06.899 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:55:07.879 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:55:08.879 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:55:08.879 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:55:09.879 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:55:09.879 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:57:51.492 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:57:54.239 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:57:54.243 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:57:55.239 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:57:56.239 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:57:56.239 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:57:57.239 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry, Module ID: b2, Message: UTILS_StationNameCheck: character “” not allowed in label
02.10.19 08:57:57.239 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Error Stack Entry 0: ModId: 57 ErrCode = 0xD357060B, AddInfo = 0x0 Codelab: 0x5500012B dcparp_util.c(299)
02.10.19 08:58:55.956 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 install state to INSTALLING
02.10.19 08:58:55.956 Arp.Services.AppManager.AppManager INFO - Installing app from /tmp/60002172000051.app
02.10.19 08:58:56.186 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 activation state to ACTIVATING
02.10.19 08:58:56.191 Arp.Io.EthernetIP.EthernetIPComponent INFO - 2902328000 LogStatistics cycle=26/28, active=1/6, esdk=1/6, gds=0/2
02.10.19 08:58:56.186 Arp.Services.AppManager.AppManager INFO - activating app 60002172000051
02.10.19 08:58:56.190 Arp.Services.AppManager.Services.Internal.AppManagerServiceImpl ERROR - ChangeAppStatus failed with AppNotInstalled: App 60002172000051 can not be activated, because it is not installed
02.10.19 08:58:56.192 Arp.Services.ProfiCloud.Internal.Processes.BaseProcess WARN - Could not activate app 60002172000051. Error AppNotInstalled - App 60002172000051 can not be activated, because it is not installed
02.10.19 08:58:56.192 Arp.Services.ProfiCloud.Internal.ProficloudAppAdapter INFO - Changed app 60002172000051 install state to INSTALLED
02.10.19 08:58:56.192 Arp.Services.AppManager.AppManager INFO - Disabling installation Mode
02.10.19 08:58:56.192 Arp.Services.AppManager.AppManager INFO - Installation Mode disabled
02.10.19 08:58:56.212 Arp.Services.AppManager.AppManager INFO - Disabling installation Mode
02.10.19 08:58:56.215 Arp.Services.AppManager.Services.Internal.AppManagerServiceImpl ERROR - DisableInstallationMode failed with InstallationModeInactive: Installation Mode is already deactivated
After a “Factory reset” installation worked using the PLCnext store and Firmware 2019.9 Kind regards, Ivan.
