Good evening, After installing plcncli and starting the extraction : plcncli install sdk -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2020.0.sh -d /opt/pxc/sdk/AXCF2152/2020.0 I got an error: The format of the file ‘/home/jeanfrancois/plcncli/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2020.0.sh’ is not supported. Please proceed manually. Can you please help me ? Thank you, Jean-François Simon
Hi Jean-François I can replicate a similar error:
The format of the file '/home/tcs-user/Downloads/pxc-glibc-x86_64-rfc4072s-image-sdk-corei7-64-rfc480-64-toolchain-2020.6.sh' is not supported. Please proceed manually. > -> An exception occured while inspecting the script. > Permission denied > -> Permission deniedThis happens if the current user does not have execute permission on the
.shfile. This is indicated by the “Permission denied” message. Do you also see this message? Can you confirm that the user has execute permission on the .sh file? Regards,
Martin.
