From the onset may i point out that i am a complete novice.
I am using the PLCNEXT Starter kit (1188165) with Left Alignable Interbus Master AXC F XT IB (2403018) connected to a single IBS IL 24 BK – T/U – PAC . The bus coupler is populated with 1 x DI Module IB IL 24 DI 4 – PAC and 1 x DO Module IB IL 24 D08/HD-PAC. The idea is to have multiple bus couplers in the field , 100m apart . Each with the DI and DO module.
I have followed examples and application notes found on this website.
Interbus Physical Addressing ah_en_left_alignable_interbus_master_108949_en_00.pdf
* https://www.plcnext-community.net/infocenter/product_range/axc_f_xt_ib_physical_addressing/
* Interbus Logical Addressing https://www.plcnext-community.net/infocenter/product_range/axc_f_xt_ib_logical_addressing/
But with no success. While following application note 108949_en_00 Left Alignable Interbus Master , i lose myself on page 14
Insert all the necessary worksheets in the POU.
• To do this, click on the arrow on the right next to the designation of the editor.
• From the drop-down list that opens, select the desired code worksheet.
• Change the designation of each newly inserted “Code” editor.
What are the necessary worksheets?
Programming INTERBUS startup
Once you have inserted all the necessary worksheets and created all the necessary data types, program INTERBUS startup in structured text (ST) programming language using the IB_CONTROL_NEXT function block.
What are the necessary Data types?
Would greatly appreciate a working example of interbus with physical ad logical addressing and any other assistance and pointers.
