Hello I have installed PC Worx Engineer 7.2.1, on 2 computers with Win 10, Release 1709. I’m running on trial license, and when i want to compile the project i get the Error: Code: SLP00003 Description: Invalid safety seal for the POU ‘UDINT_TO_SAFEUDINT’ in the Safety Libary IEC 61131-3… I have installed on a brand new computer with no other software installed, with the same result. I have tryed to compile/build/rebuild the demo project, with the same result? What to do now? - Emil
I found a solution. If i deleted the safety libary from C:\\Program Files (x86)\\Phoenix Contact\\PC Worx Engineer 7.2\\DefaultLibraries then it could build with out Errors. - Emil
Hello Emil, okay this is the first time I hear of this bug. Wich project exactly are you trying to compile? Do you have PC Worx Engineer Build 3.11.104.0 ? I am not able to reproduce this.
Can you upload the Library you deleted , the project and some system information collected with msinfo32?
press Windows + R
type msinfo32 and press enter
copy all items from the systemoverview.You can upload a zip here for example: ShareFile
Hello Here is a Video of the problem https://youtu.be/OjnvLWKI7nM In the video i try to compile a sample project, a blank project, a sample hmi project, and a new with and with out plc.
Same result. when i delete the safety file at last, it worked fine. I have now tryed at 7 different computers + 1 virtuel. all. with same problem. ? The programming software are downloaded yesterday from Phoenix contact Eshop in DK and Germany. I have uploaded a project and the libary to your server. Here is info from my workcomputer: OS-navn Microsoft Windows 10 Pro
Version 10.0.15063 Build 15063
Anden OS-beskrivelse Ikke tilgængelig
OS-producent Microsoft Corporation
Systemnavn EMIL-PLC
Systemproducent LENOVO
Systemmodel 3493DEG
Systemtype x64-based PC
System-SKU LENOVO_MT_3493
Processor Intel(R) Core™ i7-3770S CPU @ 3.10GHz, 3101 Mhz, 4 Kerne(r), 8 Logisk(e) processor(er)
BIOS-version/dato LENOVO F1KT54AUS, 15-07-2013
SMBIOS-version 2.7
Version af integreret controller 255.255
BIOS-tilstand Ældre
BaseBoard-producent LENOVO
BaseBoard-model Ikke tilgængelig
BaseBoard-navn Hovedkort
Platformrolle Skrivebord
Sikker bootstarttilstand Ikke-understøttet
PCR7-konfiguration Binding er ikke mulig
Windows-mappe C:\\WINDOWS
System-mappe C:\\WINDOWS\\system32
Startenhed \\Device\\HarddiskVolume1
Landestandard Danmark
Abstraktionslag for hardware Version = “10.0.15063.850”
Brugernavn Emil-PLC\\Emil
Tidszone Rom, normaltid
Installeret fysisk hukommelse (RAM) 8,00 GB
Fysisk hukommelse i alt 7,83 GB
Tilgængelig fysisk hukommelse 2,99 GB
Virtuel hukommelse i alt 15,8 GB
Tilgængelig virtuel hukommelse 10,0 GB
Plads til sidefil 8,00 GB
Sidefil C:\\pagefile.sys
Understøttelse af enhedskryptering Årsager til mislykket automatisk enhedskryptering: TPM er ikke brugbar, PCR7-binding understøttes ikke, Brugergrænsefladen til test af hardwaresikkerhed mislykkedes, og enheden er ikke InstantGo, Der er registreret DMA-kompatibel bus/enheder, som ikke er tilladt, TPM er ikke brugbar
Hyper-V - VM-udvidelser af overvågningstilstand Ja
Hyper-V - Udvidelser af adresseoversættelse på andet niveau Ja
Hyper-V - Virtualiseringsaktiveret i firmware Ja
Hyper-V - Forhindring af datakørsel Ja
Hey Emil, could it be that on your PCs an Early Adopter Version of PC Worx Engineer was installed and that this version was not deinstalled before you switched to the release? I noticed that this library does not get installed when I install the same Software you have.
I guess something went wrong during the installation because of a previous Beta Version
- Try deinstalling PC Worx engineer 2) delete the Documents/PC Worx Engineer Folder 3) delete the C:// ProgramData/PHOENIX CONTACT/PC Worx Enginer** Folders. 4) install PC Worx engineer 7.2.1 again.
Hello I have tryed to uninstall and delete folders, and installed a version from Eduard Münz, on fastviewer support, and the problem is still the same.
I haven’t found other solution for this problem, than delete the safety libary. I have spoked to Dan Moeller from Automation support in Denmark, but he have the same safety libary, but no fault on his computers.? I really can’t find the problem. I have tryed 8 different computers now, and it’s all the same problem. - Emil
Hello Emil, we are currently working on a fix for this issue.
Apparently it is an issue caused by the danish Windows Version.
This has been forwarded to the development and will be fixed in the next releases.
