IO-Link and ifm TV7105 temperature sensor
Hello, I have AXL E PN IOL8 DI4 M12 6P in PROFINET and I tried to configure ifm TV7105 IO-Link temperature sensor with the PLCnext Engineer 2021.6. I imported IODD-file and it is visible in COMPONENTS view. However I’m not able to use it inside IO-Link master. I.e. if I tried drag and drop, I got the message “the operation could not be executed”. See attachment for further info. FYI: I was able to configure the temperature sensor manually via Parameters, i.e. without IODD-file. Best Regards, Reijo Leinonen
Unfortunately the AXL E PN IOL8 DI4 M12 6P does not support IODD. From the manual: [attachment]inline1491895393.png[/attachment] .
Hello Martin, Thank you for very fast replay. Can you say which IO-link master modules support IODD file configuration? Intention is to use PROFINET or Axioline. Best Regards, Reijo Leinonen
Hi Reijo, Those I/O modules are not part of the PLCnext Technology family, but I have just got this information from the IO Support guys: [quote]If you use a AXL F BK with an IO-LINK Master you can use our IO-Link configuration tool for IODD configuration. The tool can not be use with AXL E IOL. With the IOL MA8 PN DI8 - 1072838, IODDs can also be used. However, with this module works via the Web Page in the IOL device. [/quote]If you need more help with these I/O modules, it is worth contacting the technical specialists in your local Phoenix Contact office.
