Hi there, I am having trouble reading the IOL4- iolink master device into the profinet side
- I can easily add iol4 to the axioline F devices (the not profinet)
- If I ‘Read profinet devices’ the slot with the IOL4 comes up with a question mark
- If I look at the diagnostics of the profinet - local bus I see the axl se iol4 and If I click on that it says the status is OK
- If instead I try to add the module manually → dbl click axl-f-bk-pn → module list → I can’t find IOL4 as an option, I can find IOL8.
- But if I search IOL4 under components it comes up as an option. (under I/O function module there are 7 options.. under module list there are 6 options)
Please help
