Ipkg cannot install gcc package
I try to install “gcc” package via using ipkg but the problem is it stuck in downloading process. So in this case can I download ipk directly from nslu2-linux.org then install it manually from shell. But I really don’t know what to command to do that can anyone suggest me. PLC - AX 2152 FW 2019.0.4 LTS (19.0.4.22338 )
Hello, were you able to download other stuff fine? → maybe something with the connection in generel is wrong? yes Make worked fine Gcc is pretty large so maybe check the storage space of your device “df -ha”
Maybe you can finde the commands at the ipkg man pages? kind regards,
