Hello!
I was interested to know if Arabic language is supported in PLCnext as I was not able to find anything about this online.
Hello!
PLCnext Engineer supports the translation of HMI texts into other languages. This allows you to create multilingual HMI applications. Using the predefined application local tag LanguageCode, the language of user-defined text strings (e.g., object labels, text list entries etc.) can be switched at runtime. : PLCnext Engineer Online Help
Arabic (ar) is currently not included in the list of available languages. I will check if there is a possibility to add it in the future.
For text fields, Arabic can be used as long as the browser supports the language.
Is this the information you were looking for?
Best regards,
Jorne
