Is it possible that PLCnext 1152 can send an email when a variable goes "true"?
I need a message on a email, SMS or other system when a variable goes “true”. The PLC is connectet to internet through a GSMrouter. Is that possible?
Hello, If you are using PLCnext Engineer, you can use the IT Library to send emails. If you are using a TC Router from Phoenix Contact, then you can set that up to send emails and SMS messages. The SMS library in the PLCnext Store can help with this. Hope this helps. ~ Martin.
