Hello everyone, I lost my PC Worx Engineer Project and was wondering if it is possible to retrieve the code from the controller as was possible with PC Worx 6.3? Best regards, Stijn Noppe
Did you check if the AutoSave.pcwex file is hanging around somewhere in your computer ?
Hello Stijn, this is a feature that will be included sometime in the future for the AXC F 2152 The AXC F 1050 already supports the feature of “Include sources”.
This feature will enable you to download the PCWEX File along the binaries it can then be downloaded. It is not possible to restore the Project Sources from the binaries alone.
So if you did not select specifically to attach the sources you will not be able to download them… Kind regards, Oliver
