Is there a way to use WebVisit (for AXC F 1050) with PC Worx Engineer
Hi, is there a way to use the old WebVisit on Projects for AXC F 1050 while using PC Worx Engineer as the IDE for the IEC61131-Part? Thanks in advance, Falk
Hi Falk, the AXC F 1050 is completely designed to be used with PC Worx Engineer and the integrated HMI Editor. This is also the reason why we decided to have the AXC F 1050 parallel to the “normal” AXC 1050. AXC F 1050 → Target for PC Worx Engineer 7.x (HMI) AXC 1050 → Target for PC Worx 6 and Webvisit Cu Frank
What a shame, since there are quite some features missing at the moment (like trending) But thanks! I guess this will clear itself up then - in some years :slight_smile:
Hi Falk, it won’t take years and I believe you will like the new implementations of the user management, alarming and trending inside the PC Worx Engineer HMI. Just wait until November for the new version 7.3 and the release on the SPS/Drives :blush:. Take care, Frank
