Hello, I am trying to use the FTP file copy block. When I am running the block I can get onto the server (in this case an Omron HMI) and I can get the file. I am not able to copy it to the destination, the destination is the PLC Next itself. I keep getting the error message that both sockets are occupied. Can someone take a look at the block and let me know if I am masking a mistake. Right now I am just using a text file for testing because they are so small an easy to work with. Any help is appreciated. I am sure it is something simple. I do have 2 of the IPC SOCKET blocks running and they are both connected to unique variables.
Hello, Please refer to: https://www.plcnext-community.net/en/discussions-2-offcanvas/copy-file-between-plcs-with-fb-in-it-library.html#reply-4358 Kind regards, Oliver
